Mach Discussion => General Mach Discussion => Topic started by: smartdrive1 on October 27, 2014, 07:00:42 PM
How can I show the values of parameters which are being used by the program ??
I am working on a general purpose code to execute a series of moves (G0, G1, G2 or G3) using data from a table - but there is a problem somewhere and I need to know if the correct values are being entered into parameters from the table - but I cannot find in the manual any way to see the values as the program is running.
Any ideas most appreciated - when I have fixed it I will publish here.
There is a Var monitor built into Mach3. Open it and assign whatever #var numbers you need to see. It runs in a seperate window so you can run mach3 and watch the vars at the same time.
(:-) TP
BR549 Excellent thanks - sounds like the answer to my problem - but where is it located please ???,
I have searched evrywhere I can think of but not located - nothing in manual.
Many thanks
I do not have mach3 loaded on this PC but it is in one of the pull down menus on the top of the screen. I think it is in the operator pull down menu.
