Hello Guest it is November 23, 2026, 12:01:20 AM
Author Topic: mach 3 on a link 0609 Cnc machine from China  (Read 9293 times)
« on: October 26, 2014, 12:34:47 AM »
Hey to all i have bought a Cnc from Link .com and have trouble to get it to work it is connect with a Usb port and a few days ago i was lucky enough that it did cut out a test code that i wrote but the thing has it now that it does not do any thing any more as soon as you import a G code the spindle starts to run the table moves to a position and that is it the code keeps on running on the screen but the table is not moving at all any ideas in what i can do to fix it  i am  new to cnc and Gcode so i could need some help Thanks remco
Re: mach 3 on a link 0609 Cnc machine from China
« Reply #1 on: October 26, 2014, 12:03:56 PM »
Sounds like the controller is the problem, best talk to your supplier to see what the issue could be.
« Reply #2 on: October 26, 2014, 04:25:29 PM »
Thanks hood any idea what a z++ limit trigger means
i have tried to run the scorpion G code file that is in the mach 3 folder as that is in mm the first time it all went ok then for the second time i got this rest message z++ limit trigger
any ideas thanks remco
« Reply #3 on: October 26, 2014, 04:53:07 PM »
It means your Z positive limit switch is triggered.
