Mach Discussion => General Mach Discussion => Topic started by: remcomayer on October 26, 2014, 01:34:47 AM
Hey to all i have bought a Cnc from Link .com and have trouble to get it to work it is connect with a Usb port and a few days ago i was lucky enough that it did cut out a test code that i wrote but the thing has it now that it does not do any thing any more as soon as you import a G code the spindle starts to run the table moves to a position and that is it the code keeps on running on the screen but the table is not moving at all any ideas in what i can do to fix it i am new to cnc and Gcode so i could need some help Thanks remco
Sounds like the controller is the problem, best talk to your supplier to see what the issue could be.
Thanks hood any idea what a z++ limit trigger means
i have tried to run the scorpion G code file that is in the mach 3 folder as that is in mm the first time it all went ok then for the second time i got this rest message z++ limit trigger
any ideas thanks remco
It means your Z positive limit switch is triggered.
