Hello Guest it is November 11, 2026, 11:13:27 PM
Author Topic: Scale problem  (Read 8786 times)
Scale problem
« on: October 21, 2014, 03:57:34 AM »
i have a problem with my Mach3 and i cant find what is causing it,
i am using it with Cut2d and a CNCrouter parts pro 4848 machine.
Every job code i export from Cut2d it loads 10 times bigger in mach3, i have to scale all axis down to 0.1 to get the job in the right size.
I am using metric everywhere.
The problem is 100% identical to everything i export so it looks like a wrong setting somewhere but i cant find it.
Any ideas?
George
Re: Scale problem
« Reply #1 on: August 23, 2016, 01:16:21 PM »
Hello and help,  I finally have the cnc hot wire machine running.  Problem is with scale, the parts are 12.56 times larger then the dimensions.  Any leads to fix would be much appreciated.....  Larry
  •  9,377 9,377
Re: Scale problem
« Reply #2 on: August 24, 2016, 12:38:00 AM »
1) Check that your Gcode file has a G20 or G21 (as appropriate) in the header.
2) In the Settings screen try the Axis Calibration feature – Set Steps Per Unit.
