Hello Guest it is November 13, 2026, 09:59:48 AM
Author Topic: z axis sometime moves the wrong way  (Read 8012 times)
« on: September 22, 2014, 11:04:38 AM »
my z axis moves the wrong way sometimes.  x and y are ok
It happens in a program and when I use the manual pendent on the screen.
I mouse click in the arrow u it goes down I mouse click on it again it goes up.
I'm not sure were to look I have checked for loose wires but no luck so far.
Thanks ,john
Re: z axis sometime moves the wrong way
« Reply #1 on: September 28, 2014, 01:37:19 PM »
Sounds like a Dir wire not making correct contact or possibly a fault in the hardware.
You say however you can not find a loose wire so if you attach your xml I will have a look through that to see if I can find an issue with your Mach config.
