Hello Guest it is November 22, 2026, 10:03:19 PM
Author Topic: Disable Z axis  (Read 10691 times)
Disable Z axis
« on: September 21, 2014, 05:48:03 AM »
Hi all
I use Mach3 to control a CNC sewing machine with the tool path (Sewing directions) written with Vcarve.
Is there a way I can forget abut the Z axis? At this stage I have to just set a single cut depth and do one pass, it has delays where its driving the Z to safe Z and then back to the requested cut depth. Would be easier just to forget about Z....
Thanks Dave
Re: Disable Z axis
« Reply #1 on: September 21, 2014, 08:25:22 AM »
Goto config>safe z and disable with the check box at the top of the window.
Re: Disable Z axis
« Reply #2 on: September 21, 2014, 09:12:22 AM »
Cool, I'll have a look when I get back home.
