Hello
Guest
it is
November 13, 2026, 11:56:11 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Two 3 axis usb controlles
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Two 3 axis usb controlles (Read 10309 times)
Venan
3
on:
September 19, 2014, 04:05:14 PM »
Hi gys!
It is possible to use two 3 axis usb controlles like this one:
http://www.ebay.com/itm/CNC-USB-Card-3-Axis-MACH3-200KHz-Breakout-Interface-Adapter-/161086021824?&_trksid=p2056016.l4276
to build a 6 axis CNC machine?
Thank you in advance!
Logged
ger21
6,295
Re: Two 3 axis usb controlles
Reply #1 on:
September 19, 2014, 05:01:18 PM »
No, but you can use two parallel ports, or a Smoothstepper.
Logged
Venan
3
Reply #2 on:
September 19, 2014, 05:08:00 PM »
Can i use this one:
http://www.cncrouterparts.com/ethernet-smoothstepper-setup-guide-p-286.html
for 6 axis machine?
Logged
ger21
6,295
Reply #3 on:
September 19, 2014, 05:19:59 PM »
Yes
Logged
Venan
3
Reply #4 on:
September 19, 2014, 05:28:59 PM »
After the smootstepper (on port 1-3) what i have to connect - two 3 axis controllers or directly the step drivers?
Logged
Print
Pages:
1
Go Up
« previous
next »
