Hello Guest it is October 02, 2026, 08:58:36 AM
Author Topic: Heeeeeeeelllllpppp  (Read 22282 times)
Heeeeeeeelllllpppp
« on: September 15, 2014, 02:31:42 PM »
Well, i come to you guys as i need help.
Bought a cheapo (well relatively) 3040 cnc router and installed all the mach 3 software and then spent three days banging my head against a brick wall trying to get ANYTHING to work.
Yes, i am a newbie and probably need all the help i can get with setting up this damned machine, so if anyone fancies a huge challenge, then pleeeeeeeeeeeeaaaaaaaaaasssssssseeeeeeeee HELP !!!
Re: Heeeeeeeelllllpppp
« Reply #1 on: September 15, 2014, 06:26:21 PM »
i may be able to help what are your problems
Mike Irvin
l
Offline ZASto
  •  434 434
« Reply #2 on: September 16, 2014, 01:44:44 AM »
Have you read the Mach3 manual?
I would start from there :)
Make no mistake between my personality and my attitude.
My personality is who I am.
My attitude depends on who you are.
Offline dude1
  •  1,253 1,253
« Reply #3 on: September 16, 2014, 03:08:04 AM »
give more info on the machine set up speeds and feeds you have set it to.
list what you have tried
have you conformed the computer is connecting to the bob.
what is the bob make model what ever, stepper size , what make are the stepper controllers, is the power supply working.
and have you read the manual.
« Reply #4 on: September 16, 2014, 12:18:05 PM »
Need Help as well!!  Starting to use my home built cnc, and not sure if my steps per are calculated correctly.  I am using xylotex 4 Axis 36V 3.5A Drive Box with Four 425 oz.in. Stepper motors with mach 3 on windows xp.  1/2 - 10 5 start lead screws .    MY problems is drawing in vcarve pro, I draw a 24" diameter circle and mach 3 cuts a 12" circle. What am I doing wrong?
« Reply #5 on: September 16, 2014, 12:29:59 PM »
set  v carve material setup make sure material is 24 x 24 or larger make sure datum position is set  to  x0 y0  NOT center  make sure  "use offset" is unchecked
Mike Irvin
« Reply #6 on: September 16, 2014, 12:41:33 PM »
Have been doing that and getting the same result every time.  Everything is scaled to 1/2 the size I draw.
« Reply #7 on: September 16, 2014, 12:47:13 PM »
Is mach3 set to 1.000 on all the scales
« Reply #8 on: September 16, 2014, 12:52:40 PM »
Where would I look?
« Reply #9 on: September 16, 2014, 01:00:36 PM »
Sorry really new to this. So far this is my only problem.
