Hello Guest it is November 13, 2026, 11:48:59 AM
Author Topic: Do I have a problem  (Read 11354 times)
Offline 1Acnc
  •  28 28
Do I have a problem
« on: September 07, 2014, 12:59:36 PM »
When on the Program Run page, my my keyboard short cut keys ( the 4 arrow key and I am using A and Z for Z axes ) work to move the DRO and the motor run. If I go to the Tool Path page they stop working. I can hit the TAB key and the jog screen appears and the mouse can be used to move the motors. If I go to the diagnostics page, the hot keys work fine for moving the motor and DRO. Is this the way it works or do I  have something set wrong? The reset button is green. Using a Dell machine, with XP and Mach 3.   ???
Re: Do I have a problem
« Reply #1 on: September 07, 2014, 04:16:03 PM »
same here .hope to get a reply
« Reply #2 on: September 07, 2014, 07:45:30 PM »
You cannot jog with the keyboard from a page that does not have the jog enable LED on it.
Offline 1Acnc
  •  28 28
« Reply #3 on: September 07, 2014, 10:08:33 PM »
I looked at the Tool path page, I did not find anyplace to turn on the Jog LED , is that correct? So you are saying that you can not use key board short cut keys on the Tool Path page?
« Reply #4 on: September 08, 2014, 12:55:43 AM »
You could use one of the screen designers to add the Jog  enable LED to that page and it will work.
Offline 1Acnc
  •  28 28
« Reply #5 on: September 12, 2014, 09:48:39 PM »
Thanks to all that replied.
I have been resisting learning about screens, the learning curve for this hobby is steep. CAD, CAM, Mach 3  and G_Code. I just did not want to learn one more thing. I have been reading this forum for some time and kept seeing Screen were the answer to many problems or questions.
I did not know what is was, now I do. I am going to post a little of what I learned.
Again thanks
