Hello Guest it is November 22, 2026, 04:39:07 PM
Author Topic: cut2d and mach3 says 6" but is it?  (Read 14000 times)
« on: September 05, 2014, 10:05:20 AM »
I design a job to be done and make it a work area of 6x4 and a pocket cut of 5x3 choose all the settings for that and tool choice etc. ;D
All in inches, verify and reverify. :D
Save it to mach3 inches text ;D
hand it over to mach3 ;)
load 8)
and whamo...I am watching in frustration as the mill is cutting a 1x1/2 pocket about 1/100th" deep ???
I checked everything I could and redrew the whole thing on different programs and I still get the same issue.  I even run the projects on mach3 and they do the same thing.
has any one else run into this problem before? >:(
Re: cut2d and mach3 says 6" but is it?
« Reply #1 on: September 05, 2014, 10:40:12 AM »
Make sure the default units in Mach3 are set to inches.
Then, make sure you're in inch mode (G20) and use MDI to move 1". Make sure it moves 1".
« Reply #2 on: September 05, 2014, 11:05:06 AM »
Thanks I havent done the MDI portion.  Still new to this.  Will give it a shot.  If it doesn't move 1" what then? lol
« Reply #3 on: September 05, 2014, 11:32:15 AM »
Well I am a blazing idiot.  I have no clue as to what to do with MDI.  I have a lot of reading to do. Hope I don't fall asleep before I can learn something as it looks more dry reading than the introductory page of Linings and Coatings for beginners.
« Reply #4 on: September 05, 2014, 11:57:04 AM »
This ....
              ... for starters.
Russ
« Reply #5 on: September 05, 2014, 12:34:50 PM »
well its clearly obvious I am going just less than 1/4 of travel than commanded so somewhere in my setup/config I have not done something right.  I need to scour the settings and the manual and see where I screwed up.  I select 4" of travel and it gives me just over an inch
« Reply #6 on: September 05, 2014, 02:05:44 PM »
Change your steps/unit in Motor Tuning.
« Reply #7 on: September 05, 2014, 02:43:45 PM »
up or down?  I started at 3200 steps, got all the way to 15,000 steps which gave me about a 2:1 difference instead  1:4  So I can get it to move 2" when I tell it to go 4" before it was 3/4" when told to go 4".  So I am stuck.  I go much higher that 15k and the motors freak out and stop
« Reply #8 on: September 05, 2014, 05:00:24 PM »
Ok, I have figured it out.  I tried everything I could.
It came down to scale.
I had to set it at 2.1250 to make it give me exactally 1 inch to 1 inch move.
Already had some jobs being done.
Life is now good!
