Hello Guest it is November 24, 2026, 02:12:04 AM
Author Topic: Breakout board turns off when opening mach3  (Read 9719 times)
« on: August 02, 2014, 06:22:05 AM »
Newbie here.
When i start my computer the led on the BOB lights up until i open mach 3.  When i open mach3 the BOB light turns off and won't turn on again until i restart my computer.  I believe it could be my setting in mach3 because even if i disconnect the BOB and use a voltmeter to watch the parallel port pins i see the power turn off when starting mach 3.
Have a longs kit (bob db25-1205, 3 axis, dm860a drivers) wired up according to the included schematic.  Running a 32bit machine with an onboard parallel port.  Parallel port is set to lpt1, hex 378, bios for the port is set on ecp mode.
I have tried with "motor outputs" and "input signals" selected as enabled and also turned off.  I have tried all combinations of enabled and active high/low for the estop setting.
Inputs greatly appreciated.  Thank you.
  •  9,378 9,378
Re: Breakout board turns off when opening mach3
« Reply #1 on: August 02, 2014, 07:23:52 AM »
Are you trying to power the BOB from your parallel port ??
« Reply #2 on: August 02, 2014, 08:42:04 AM »
I was.  The longs diagram doesnt show an additional 5v power supply so i thought the parallel port must power the board.  Since figured out that i need an external supply.  I hooked one up and the board is working.    Thank you for your reply.  Now my issue is that i only get one motor pulse when jogging before the driver faults.
