Hello Guest it is September 29, 2026, 06:24:27 AM
Author Topic: I have a new xp computer  (Read 9531 times)
« on: August 01, 2014, 10:11:42 PM »
This is a new xp computer that i will use only for cnc routing. It does not have access to the internet. I want to purchase Mach3 with my computor that access's the internet but does not have a serial port like the xp computer which i need to run Hobby cnc.After purchase can i down load mach3 to a thumb drive and install it on the xp or is it only good to run on the downloading computer ?
  •  9,374 9,374
Re: I have a new xp computer
« Reply #1 on: August 02, 2014, 02:09:47 AM »
Hi Mrputz1,
You can download the Mach3 version of your choice, copy this download to a thumb drive then install it on any computer. The Mach3 license can be copied to your thumb drive and then copied to any computer in a similar manner.
Hope this helps.
« Reply #2 on: August 02, 2014, 09:08:59 AM »
Thank you so much . I am new and going to build a cnc router, I did not want to purchase the software if i could only use it on one computer.
« Reply #3 on: August 18, 2014, 05:25:25 AM »
Hi -
You can buy a USB to Serial lead (£1.15) or a Pci to two Serial ports card (£3.00 approx) both from Ebay. Cheaper than a new computer!
Regards - Dozee
