Hello Guest it is October 21, 2026, 08:56:31 AM
Author Topic: 3020t problem  (Read 24347 times)
3020t problem
« on: July 26, 2014, 05:42:17 PM »
I need help i can setup and run but as soon as i reboot i have to reset up the home switches  go to configure ports and pins "check" MAX nc 10 shut down the program restart mach3 go to configure ports and pins "UNcheck" MAX nc 10. then everything is ok this happens on all my computers i tried.  this is a LICENSED copy of MACH3
Mike
Re: 3020t problem
« Reply #1 on: July 26, 2014, 06:06:06 PM »
Attach your xml and I will take a look, cant think what would be the cause of that.
Re: 3020t problem
« Reply #2 on: July 26, 2014, 06:17:26 PM »
Sounds like your Z is set up to go the wrong direction or possibly you are just homing it in the wrong direction.
If you look lower right on the screen in Mach you will see the name of the profile you are using. Close Mach then go to the Mach3 folderon your drive and look for a file of that name with a .xml file extension. Copy it to your desktop and rename to MikeIrvin.xml then use the additional options button on the reply page to attach it to a post.
Sorry ignore this,  posted in the wrong thread.
« Last Edit: July 26, 2014, 06:31:47 PM by Hood »
Re: 3020t problem
« Reply #3 on: July 26, 2014, 06:34:19 PM »
the mike1.xlm  lets me run ok i rebooted and that is mike.xlm not working
Mike
Re: 3020t problem
« Reply #4 on: July 26, 2014, 06:39:38 PM »
Ok its the early hours here so will have a quick look but unless I see anything obvious it will be morning before I post back.
Re: 3020t problem
« Reply #5 on: July 26, 2014, 06:43:28 PM »
ok thanks also i renamed after copying it not the original
Mike
Re: 3020t problem
« Reply #6 on: July 26, 2014, 06:45:11 PM »
Seems to work fine here, if I open your Mike profile, uncheck the Max mode, shut down and restart then it is still unchecked.
Try that and see if it still comes up checked, if it does then look at the xml properties in your Mach3 folder and see if for some reason it is set to read only.
Re: 3020t problem
« Reply #7 on: July 26, 2014, 08:30:05 PM »
something is wrong i just hit edit gcode and all it dose is regen dose not open the editor
i tried what you said and that makes it work but a reboot kills it
Re: 3020t problem
« Reply #8 on: July 27, 2014, 04:31:24 AM »
Not sure what you are meaning but think you are saying if you change to Max unchecked, restart Mach then its fine, but if you shut down your computer and restart then when you open Mach iMax mode is checked again. Is that what you are meaning?
If it is then I think you must have something that sets the computer back to original state each time you close down, there are many programmes that can do that and possibly even can be set in recent Windows versions.
Regarding the editor, it is most likely that Mach is looking in the wrong location for notepad, you can change where Mach looks on General Config page.
Re: 3020t problem
« Reply #9 on: July 27, 2014, 07:18:07 AM »
1  Start program   max nc 10 unchecked      not working
2  check max nc          not working
3  restart mach3   max nc checked       not working    dro's move steppers  x y  make a noise  but not Z
4  uncheck max nc       all  works fine    but need to re assign home switch pin numbers  the limit switches are ok
5  close mach3 and restart 100 times   working
6  reboot computer   Not working
This happens on both computers  One a dell and a gateway and always did .
 the editor i now understand  Thanks
