Hello Guest it is October 16, 2026, 03:44:03 AM
Author Topic: MachTurnNo2  (Read 7814 times)
MachTurnNo2
« on: July 11, 2014, 10:55:10 AM »
I have an Orac lathe converted to Mach several years ago, the computer hard drive failed, I have since got a used computer with XP and loaded Mach also the C11.xml file that I had a copy of.
As I have not used the lathe for years, and my memory on how to use it is fuzzy, in manual mode the spindle runs, but I can’t get it to jog, tried with jog on and jog mode on and off.
I think there is something simple I am not doing? I have attached the xml if that helps
Could someone advise please?
Mike
Re: MachTurnNo2
« Reply #1 on: July 12, 2014, 08:47:06 AM »
Problem solved, computer issue
Mike
