Hello Guest it is November 13, 2026, 05:19:06 PM
Author Topic: Pokeys on board power supply  (Read 35533 times)
« on: July 10, 2014, 11:42:19 PM »
Is it OK to use the 5v and 3.3v terminals on the Pokeys 56U to power analog inputs and rotary encoders or should I use a separate power source for these?
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pokeys on board power supply
« Reply #1 on: July 11, 2014, 03:18:25 AM »
Please take a look at the 6.4.  Electrical specification – static characteristic table in the PoKeys manual. The 5 V pin can be used to source up to 400 mA, while 3.3 V pin can source up to 120 mA.
« Reply #2 on: July 11, 2014, 07:19:01 AM »
Thanks for your reply. I do have a separate source which I will probably use on the final panel build but whilst experimenting its nice to keep it a bit more simple and use the on-board supply.
I had my first play with the Pokey 56U tonight and found it very nice to use. Set up  a pushbutton switch, an encoder, a potentiometer, a toggle switch, some rotary switches and mapped them to Mach 3. Had a fair bit of success getting them to do what I wanted to do, but have a couple of issues you may be able to help with.
I've mapped the rotary switch to the step increments and they are changing fine on the Mach3 MPG screen, but when I turn the encoder 1 detent, it doesn't matter what step value is set, the axis only moves .0635mm This is OK as when I turn the encoder as fast as I can, its about at maximum speed for my steppers, I would just like it to be multiples of 10.
I want to use the toggle switch to turn block delete on/off. I assume I would need 2 inputs to Pokeys from this switch - 1 for on and 1 for off and map them to block delete on and block delete off. As this is controlled by a single toggle button in Mach 3, I guess I would need to create a separate on and off button in Mach 3 to get this to work?
Pokeys is seeing the potentiometer and I can see the voltage varying from 0-3.3v but I cant work out what DRO to map it to to get the feed rate override changing.
I'm sure I would eventually work these out, I guess I am just excited and want to get it all up and running.
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: July 12, 2014, 05:03:30 AM »
Mach3 MPG - are you using PoKeys56U for generating pulses for the motors? There are some issues in how Mach3 handles the MPG jogging by itself (and not using LPT port for MPG).
Block delete: if you are using a button (not switch), then use the mapping to button 176, which toggles the block delete mode. If you are using a switch, map its signal to OEM LED 66.
Regarding potentiometers - to minimize the noise, it is advisable to wire the potentiometers to PoKeys's 3.3V pin.
Use OEM DRO 821 to override the feedrate DRO. Enter proper offset and gain values in the analog input dialog options (see the Pulse engine and Mach3 plugin manual on this).
« Reply #4 on: July 12, 2014, 09:01:37 PM »
No, I am not using Pokeys for generating pulses for the motors, only for "switch" inputs and maybe some LED indicators. When you say issues with MPG do you mean when using Pokeys or using the MPG in General? Yesterday I got it working nice, but now its doing some real strange things - not moving when I move the encoder, but then after a few seconds taking off and not stopping! I may have changed something whilst experimenting but I've checked all my wiring and assignments and I cant see anything wrong.
I got the pot working for feed override- as soon as I entered values for gain and override, it works. I have changed to a rotary encoder (which has a pushbutton built in for reset) as I think this will be more practical to use and this is working as expected..
Still working on the switch tho, mapping the assignment to an OEM LED does nothing.
Maybe a nice coffee and some lunch to refresh the mind will help.......
« Reply #5 on: July 13, 2014, 04:24:44 AM »
Well I have everything working now except for the toggle switches. Just cant seem to get my head around it! Even got some LEDs being controlled by the Pokey too.
I couldn't find an issue with the encoder for the MPG, so I reset all the inputs and re did the wiring so the switches were mounted on a board rather than just being connected by a jumble of wires. Working fine now, just need more thoughts about the toggle switches.
« Reply #6 on: July 18, 2014, 08:20:36 PM »
Well, I still cant get this to work. I've even tried wiring both side of the switch to the same input but I still have to do a double movement on the switch. This might be because its not an instant switch over state and there seems to be a small amount of NC to either side during transition.
I just read about using a capacitor in series with the switch may work so I'm going to try that, but surely someone has had this problem and found a work around before.
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #7 on: July 19, 2014, 02:18:51 AM »
Some Mach3 functions behave like a toggle switch and require one actuation for turning the feature on, and another one for turning it off. A workaround on some functions can be done by mapping a switch input to OEM LED (these are not only used for outputs).
« Reply #8 on: July 19, 2014, 03:08:00 AM »
Can you elaborate on mapping the switch to an LED please, no matter what I do, cant get it to work.
I assume I connect my switch to pin 12 and then in the Mach 3 plugin, I set it as an input and map the LED to 66? If that's what I do, it doesn't work. Ive also tried other LED numbers and no result either.
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #9 on: July 20, 2014, 02:28:53 AM »
It appears that Mach3 does not allow the block delete function to be controlled from a switch and requires a button instead. I would suggest replacing the switch with a pushbutton with LED.
