Hello Guest it is November 13, 2026, 05:55:37 PM
Author Topic: Pokeys on board power supply  (Read 35544 times)
Re: Pokeys on board power supply
« Reply #10 on: July 20, 2014, 05:12:11 PM »
Thanks for that advice, I was starting to think that was the case. I did try and Map to some other OEM LEDs to check my process was correct and was unable to get any of them I tried to work with the method I described above. Is that the correct process?
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #11 on: July 20, 2014, 11:02:10 PM »
Yes, your approach is correct. Unfortunately, it is unknown to me which OEM LEDs allow you to do this and which ones don't.
« Reply #12 on: July 25, 2014, 11:53:14 AM »
Just tried with a momentary switch and it is working fine here.
Alex
« Reply #13 on: July 25, 2014, 05:54:27 PM »
Hi Alex, Yes Momentary switches work fine, and I am using them for lots of other functions.
What I wanted to do was to use a toggle switch to control these functions so that pos "off" forced block delete off and position "on" forced it on. I have been able to design a little circuit that emulates a momentary switch , sends a low pulse on each change of state of the switch (on - off or off - on) and this works great, just like a momentary, except it doesn't force the state (off position on the switch can be in fact on)
I'm now looking at creating separate on/off buttons for these in mach3 and mapping 2 inputs from the pokeys to them. That's todays project, so I will report back on that one.
« Reply #14 on: July 25, 2014, 10:27:57 PM »
I understand now  what you are trying, but as far as I know this will not work because the Block Delete function is a toggeling function within Mach3.
Or in other words it can't be forced to stay on or off.
Alex
« Reply #15 on: July 25, 2014, 10:52:37 PM »
Correct, the current button in the standard set has a toggling effect.
I have created 2 new buttons in Mach3 using Screen4 with some VB script and one turns it on, one turns it off. This works well. Now I just need to map a pokeys input to these new buttons, and that is where I am struggling at the moment.
I can get it to work with assigning hot keys, but there is another issue in that these are ignored if Mach3 does not have the focus on windows.
I am starting to think illuminated press buttons will have to be the answer, but finding some with enough colour range at the right price is a challenge in itself.
