Hello Guest it is November 10, 2026, 12:41:40 AM
Author Topic: Need help with Pins and Port configuration  (Read 9191 times)
« on: July 03, 2014, 03:08:12 PM »
Hello all i am new to mach3 and am currently trying to set up a plasma machine with a slaveX/A axis.  In the (config/ports and pins/motor output screen) enable and disable motors works, but pins does not.  Doesn't matter which pin i assign or simply a 0 and when jogged the same incorrect motor will move.  Please help.  Thanks.  Chad Moore
Re: Need help with Pins and Port configuration
« Reply #1 on: July 09, 2014, 01:33:54 PM »
Please attach your xml.
« Reply #2 on: July 10, 2014, 08:36:30 AM »
I got it figured out after reading and watching the tutorials.  After hearing the description of the MaxNC and what it's purpose was for, I thought maybe this could be causing my problem.  I investigated and indeed the check box had been checked.  This was my problem Thanks for trying to help.
