Hello Guest it is October 22, 2026, 05:33:45 PM
Author Topic: Homing quit working  (Read 7924 times)
Homing quit working
« on: June 30, 2014, 01:56:09 PM »
Read through many of the posts about homing issues but could not find this problem.
Homing was working as of the other day but I have been messing with adding a wire control loom and even though I put things back to exactly the way things were (triple checked) , I can not get the machine to move when I hit the "Ref All Axis" button. It does rezero the machine coordinates but there is no movement. Yellow lights (M1, M2, and M3) come on fine when home switches are activated manually.
I have the input ports for the homing switches ticked for "active low".
I did notice that every once in a while, the M2 and M3 yellow light will flicker a bit with machine is just sitting idol.
I'm using a PC4less C10 breakout board. Are these any good? I bought this router used. Also windows XP.
Any ideas?
Re: Homing quit working
« Reply #1 on: June 30, 2014, 03:11:37 PM »
The M1, M2, and M3 yellow lights are the "home" yellow lights referred to in previous post. I noticed that he limit switch yellows are also M1< M2, and M3.
