Hello Guest it is November 13, 2026, 09:09:46 PM
Author Topic: Computer hardware for Mach?  (Read 8825 times)
« on: June 24, 2014, 06:18:52 AM »
I am just setting up a Mach 3 system with a Galil motion Controller card.  So the hard work will be done inside the Galil.
My question is, "Is Mach 3 performance overly dependent on the PC speed and RAM size?  Is a multi-processor PC an advantage?".  The PC will be dedicated to only run the Mach 3/Galil combination, no internet connection nor other software.
Re: Computer hardware for Mach?
« Reply #1 on: June 24, 2014, 06:47:08 AM »
Dont think you will have an issue with any computer you can get today when using an external controller.
On two of my machines I use Via Pico motherboards with 1Gig integrated CPU and 1 Gig RAM, the Chiron uses a mini ITX mobo with a 1.6Gig Atom CPU and 1 Gig ram and the wee lathe and coil winder both use old point of sale all in one computer/monitor/touchscreens and they have 2Gig Celerons with 1 Gig RAM.
All have onboard graphics and all are networked to my desktop computer for easy file transfer.
