Hello Guest it is September 10, 2026, 08:50:56 PM
Author Topic: Gecko 540  (Read 11158 times)
Gecko 540
« on: June 17, 2014, 08:27:47 AM »
Hi  all, long time no see.
All was working well when bang my controler gave up, I have bought a gecko 540 and have wire it up using all new wire and conectors. can anyone help I have power to motors and I can get DRO's to move in mach but I can't get the motors to run. It seems like no signal. This is my work so I need it up and running asp.
Many thanks
Mike
Re: Gecko 540
« Reply #1 on: June 17, 2014, 04:25:00 PM »
Could be many things, if you have not changed anything in Mach then it is most likely a wiring issue or possibly your port is damaged.
Check the voltages coming out of the Dir pins when you jog back and forth to see if they are working.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Gecko 540
« Reply #2 on: June 17, 2014, 05:55:47 PM »
I suspect you may not have your port&pins set up correctly for the G540. You can download one that is pre configured from Gecko, you will still need to do the motor tuning.
Happy machining , Jeff Birt
Re: Gecko 540
« Reply #3 on: June 18, 2014, 01:59:26 AM »
Hi All,
Thankyou for your replys. It was thw 25 pin cable I bought a new male to male and it did not match up. I went to maplins and bought a conveter female to male and it works.
I now have a problem on the Z it will not run smooth and go's in any direction .
Mike
Re: Gecko 540
« Reply #4 on: June 18, 2014, 03:56:41 AM »
Sounds like your Z Dir connection, and possibly also the Step connection, is faulty/loose.
Re: Gecko 540
« Reply #5 on: June 19, 2014, 01:30:35 PM »
Thanks all. All done and I am well pleased with all the help and the new Gecko.
Mike
