Hello Guest it is November 26, 2026, 05:03:16 AM
Author Topic: Why does Mach 3 need a tool length?  (Read 129839 times)
Offline Learn
  •  75 75
Re: Why does Mach 3 need a tool length?
« Reply #10 on: June 14, 2014, 10:35:33 AM »
home out = ref the X Y or Z
but I mis read it . you auto zero ti each time you tool change so that will take up time as well.
ok ill use my tool setter I have and measure the face of the spindle to the end of a holder and use that as my main cutter and store it as a tool that wont be used .
so pretty much get the length of the cutter (reference tool  ill use my edge finder)  store the number
follow this step for all other cutters
SAVE tool table
This is the part that confuses me
now do I pick that edge finder up on the work piece ? use the gauge length on the off set page  and then do I pick up all other cutters off the work piece s well??
when I post my paths make sure I use the G43 and tool number a?
Thanks for the help so far. As soon as I get off work I will go home and try this out .
« Reply #11 on: June 14, 2014, 12:53:29 PM »
Learn,
The reference tool could be any tool you use often. I use an edge finder because I use it all the time. I don't use a height gauge I use a 0.5" pin I roll under the tool. I like using a large pin so I never accidently jog the tool into the part or the table. You just tell Mach 3 the size of the pin or height gauge.
Offline Learn
  •  75 75
« Reply #12 on: June 14, 2014, 04:54:52 PM »
Gary thanks
so how do you find the length of your tool then ?
I guess I don't understand how you get your over all length then
Offline Learn
  •  75 75
« Reply #13 on: June 14, 2014, 05:57:33 PM »
Ok I am trying to get the lengths of the cutters and entering them in .
I am zeroing out a 123 block on the spindle face then putting in a cutter and moving up and getting length and trying to enter it in. Once I enter it in it looks as if it is in English. I work in metric. But that's only the tool table.
looks as if I scraped an endmill now with this last test . I'm getting frustrated with this as I can find the lengths and add them in but mach 3 is awkward for me going backwards I guess. I've been in the trade since the late 90's and thought this would be a bit easier to understand.  Grrrr
« Reply #14 on: June 14, 2014, 07:25:20 PM »
Learn,
I will admit that tool length setting in Mach 3 REALLY had me going for a while!  It took me a couple of hours one day determined to get it to work before I finally got it.  So I'll try to save you some of the tools I broke by giving you one huge hint.  When you press reset or rewind a program in Mach 3 it executes a G40 tool length cancellation automatically.  This is deadly!!  Because if you make a move with the previous tool still in the spindle it will move the Z to a zero length tool and almost certainly crash it.  The correct length for the tool doesn't get set until the program reaches a tool change for that specific tool.
In mach3 and other CNC programs the tool length is kept in a table of offsets.  The tool length gets applied at the tool change if you call the H word along with the tool number and then do a G43, which actually moves the Z to make the end of the new tool exactly where the end of the reference tool would be.
On the Offsets screen in Mach 3 in the lower right portion of the screen is where you enter the tool number and then touch off the tool to get the length.  The reference tool, my edge finder is tool zero and it's length offset is zero in the table.  All other tools get an offset plus or minus the length of my reference tool. You'll see this if you click the Save Tool Offsets button.  These offsets are retentive even if you turn the machine off.  So if you power the machine back up and pick up Z zero using the reference tool all other tools will still be the correct length when they are called, and you don't have to set them again.
If you are smart about this you may keep certain tools always in a holder and mark the holder with the tool number, then always use that tool number in your programs for that tool.  You then don't have to touch off that tool again until you change it out because it is dull.
You need to play with this some. I'll bet you view what you do at work in a new light once you have this working on your own machine.
« Reply #15 on: June 14, 2014, 07:27:20 PM »
Learn,
Bummer! I started writing the post above and stopped for dinner.  The answer to your crash is in that post.  Sorry about that.
Offline Learn
  •  75 75
« Reply #16 on: June 14, 2014, 08:04:42 PM »
Learn,
the crash was my trying to reset the machine as I made an MDI move and once I hit reset it just dives. it has happened before even when I was not trying to do anything with the offsets .
I already see things at work in a totally different way LOL.
OK let me see if I am getting this correctly
you use a center drill as our reference tool and is tool # Zero and the length you have is Zero as well?  how do you pick that reference tool up to get a length of zero?
I wish there  was a good video to watch to explain this . as the tormach one shows entering length that was from a height gauge.
Offline Learn
  •  75 75
« Reply #17 on: June 15, 2014, 03:39:55 PM »
OK I got all the tool lengths added in the mach 3 made sure everything was homed out now I am using mm not English just an FYI
I used tool 1 as reference tool just as the tormach video   shows followed step by step going over and over the video . I do a t16 m6 g43 h 6 and it has my number as a huge  negative number
what could I be doing wrong ?????  this is driving me nuts .
Offline Learn
  •  75 75
« Reply #18 on: June 15, 2014, 04:15:29 PM »
I came to a conclusion tool offsets don't work on my mach 3   I would love to speak t someone and see if it is just me
Offline Learn
  •  75 75
« Reply #19 on: June 15, 2014, 05:06:50 PM »
Edit LOL I got it to work with out using the g43 h# t# man I had tto change the numbers around neg to positive and go in a sequence and now it works . Thanks for all your help
