Hello Guest it is October 24, 2026, 04:59:43 AM
Author Topic: Z axis problem  (Read 14781 times)
Z axis problem
« on: March 19, 2007, 06:21:35 AM »
hello everyone!
I have problems configuring mach3 or maybe, on my LPT ports.
I tried mach3 version 1.84 and ver.2.0 downloaded from official site.
I have x and y axis working perfectly, but z axis doesn't.
axis A doesn't work too.
Pins for output for that axis  are 7-6 and 9-8.
In the diagnostic panel I see the pins 9-8-7-6  of the LPT light Green.
PINS 2-3-4-5 are grey instead.
I tried to assign an output to pins 9 and 7, and then set them for the spindle, and they work correctly.
I get a step on the motors every time i switch on and off the spindle.
So mach uses correctly that pins, but can't as motor ouputs.
Step pulse are 25 and 6 for the signals.
Could someone suggest me something?
The driver test is OK and the same breakoutboard is working perferctly driving all motors with EMC2 and Ninos UPA.
Thanks in advance
Andrew
Re: Z axis problem
« Reply #1 on: March 22, 2007, 07:46:25 AM »
Could you tell us what you are using for a breakout board? also sherline mode and see if that helps at all
www.newfangledsolutions.com
www.machsupport.com
Re: Z axis problem
« Reply #2 on: March 22, 2007, 08:01:59 AM »
Thanks Brian
I use a self made breakboard, using 74LS14N and pc817 optocouplers
I tried  setting sherline, but Z axiz still doesn't work.
Now I'm going ti change PC  to resolve the problems.
Now I can only suppose that. :-\
Andrew
Re: Z axis problem
« Reply #3 on: March 23, 2007, 06:45:17 PM »
Tell me if that is the problem :( I am starting to think you may have a bad cable or some thing like that ...
www.machsupport.com
Re: Z axis problem
« Reply #4 on: March 23, 2007, 07:28:16 PM »
Sure Brian
Al let you know.
I'll try with a new cable, but it's strange that EMC2 ( under Linux) and Ninos( undex XP), they work fine.
However, many thanks to everyone!
you're very kind!!!!!:)
Andrew
Re: Z axis problem
« Reply #5 on: April 12, 2007, 04:22:20 PM »
Hello.
I'm here again. :)
I changed PC and now all is working fine!
I really thank you.! ^______________^
Andrew
Re: Z axis problem
« Reply #6 on: April 12, 2007, 06:01:05 PM »
Glad to see/ hear that you got it working!
www.machsupport.com
