Hello Guest it is November 13, 2026, 07:38:54 PM
Author Topic: which Galil bds work with Mach?  (Read 77310 times)
« on: March 18, 2007, 08:34:17 PM »
Will a Galil DMC-1040 (ISA card) work with the Galil mach plugin?
From what I read, only the 18xx and 2********* series are covered. Is that right?
Doug Danielson
Atlanta, GA
Offline greg
  •  66 66
Re: which Galil bds work with Mach?
« Reply #1 on: March 22, 2007, 10:50:45 PM »
there were  3 or 4 of us asking the same ?.it must have gotten lost changing over to the new servers. any info would be appreciated. thanks greg
« Reply #2 on: March 23, 2007, 07:54:29 PM »
From what I recall reading in the past, only the PCI cards are fast enough. Brian can answer better, though.
« Reply #3 on: March 23, 2007, 08:52:22 PM »
PCI and the Ethernet versions are tested to work...
www.newfangledsolutions.com
www.machsupport.com
« Reply #4 on: April 16, 2007, 02:34:48 PM »
Brian I acquired a Galil 1842 PCI card and the interconnect breakout board. But it came with no instructions. I want it to work with mach3. So I know I need the Galil plugin for mach3. So I take it that I will need the driver for the board from Galil and then after the board is installed let windows locate the board and the driver. Is that all there is to it?
