Hello
Guest
it is
November 13, 2026, 07:40:00 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
Galil
(Moderators:
smurph
kcrouch
which Galil bds work with Mach?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: which Galil bds work with Mach? (Read 77314 times)
wddanie
4
on:
March 18, 2007, 08:34:17 PM »
Will a Galil DMC-1040 (ISA card) work with the Galil mach plugin?
From what I read, only the 18xx and 2********* series are covered. Is that right?
Doug Danielson
Atlanta, GA
Logged
greg
66
Re: which Galil bds work with Mach?
Reply #1 on:
March 22, 2007, 10:50:45 PM »
there were 3 or 4 of us asking the same ?.it must have gotten lost changing over to the new servers. any info would be appreciated. thanks greg
Logged
ger21
6,295
Reply #2 on:
March 23, 2007, 07:54:29 PM »
From what I recall reading in the past, only the PCI cards are fast enough. Brian can answer better, though.
Logged
Brian Barker
3,860
Reply #3 on:
March 23, 2007, 08:52:22 PM »
PCI and the Ethernet versions are tested to work...
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Dan Mauch
44
Reply #4 on:
April 16, 2007, 02:34:48 PM »
Brian I acquired a Galil 1842 PCI card and the interconnect breakout board. But it came with no instructions. I want it to work with mach3. So I know I need the Galil plugin for mach3. So I take it that I will need the driver for the board from Galil and then after the board is installed let windows locate the board and the driver. Is that all there is to it?
Logged
Print
Pages:
1
Go Up
« previous
next »
