Hello Guest it is October 23, 2026, 04:49:53 AM
Author Topic: Mach 3 configuring  (Read 7833 times)
Mach 3 configuring
« on: June 05, 2014, 09:31:07 AM »
Hi all.
I am a newbie to all things CNC. I have converted a HOBBYMAT BFE 65 Milling m/c to CNC control, i have downloaded the trial software for Mach3. Following the instructions for setting up the configuration, all has gone well except one thing, my Z & X axis are running smoothly, but my Y axis motor just Judders when i select it in JOG. I have checked all the wiring etc; i have power, and the dip switches are set to the makers settings for running my motors @ 4.2 amp before i go deaper without much knowledge, as anyone had a similar experience / countermeasure.
Regards
Ray
Re: Mach 3 configuring
« Reply #1 on: June 05, 2014, 12:36:16 PM »
What I would do is swap the pin assignment, in Mach, for the bad axis with one of the good ones to see if the bad axis now runs fine.
