Hello Guest it is November 13, 2026, 09:37:54 AM
Author Topic: Other interface?  (Read 10046 times)
mike542
Other interface?
« on: March 18, 2007, 01:37:51 PM »
  Hi. I finished my homebuilt cnc machine awhile back and have been using Mach 3 on a regular desktop PC with a parallel port, but  I would like to hook it up to my new Dell Laptop i'm buying. The only problem is it doesn't have a parallel port. I'm also using the 3 axis cnc pro driver board from Hobby CNC. Is there any way to use a usb port or would a expansion docking port work ( This uses the laptop's usb port and then has a parallel port, serial,etc.) Any help would be greatly appreciated. Thanks.
Re: Other interface?
« Reply #1 on: March 18, 2007, 07:32:46 PM »
You cannot use any form of USB to parallel adapter. Mach demands total control over the timing of pulses on the parallel port and will not work through a USB interface. If you could find a PCMCIA card to parallel port that might work, but Im not sure they are available.
The only way to use a laptop without a parallel port is to use a device like the ncPod or G100
