Hello Guest it is November 22, 2026, 12:13:52 PM
Author Topic: About Plasma Sheet Angle  (Read 15256 times)
« on: June 04, 2014, 09:21:28 AM »
Hi Every Single One.
I Want To Plasma Cutting machine's with mach 3
I solved everything but ı have to ask 2 questions about mach3 plasma
Question 1
can ı make sheet angle like that with mach3 ?
Question 2
How Can I add Kerf to g codes quickly. is there any plug-in or macros for that.
Thanks For your help.
Best Regards.
Re: About Plasma Sheet Angle
« Reply #1 on: June 04, 2014, 09:35:48 AM »
Do you run a THC an if so what routine code do you run to find the top of material?
« Reply #2 on: June 04, 2014, 09:39:56 AM »
No I Dont Use THC. I just use Pynomatic System like that. Up and Down
« Reply #3 on: June 04, 2014, 10:02:18 AM »
OK then you can use the G68 function in mach3 to rotate the toolpath on the sheet.
Just a note on G68 the toolpath will travel the rotated angle BUT mach3 jogs in the unrotated plane.
« Reply #4 on: June 04, 2014, 10:08:31 AM »
i know i can make that g68. but everytime i have to calculate that angle. i want to make that. first i find first corner of sheet. then i find another corner of sheet. can mach3 calculate that angle automaticly.
« Reply #5 on: June 04, 2014, 11:17:58 AM »
It can if you write a script(Mcode) to do it. There is probably a script example somewhere on this site to do it.
« Reply #6 on: June 04, 2014, 11:23:24 AM »
really i searched it so much but i couldnt find anything about it. Can you help me where is that script or smilar scripts.
« Reply #7 on: June 05, 2014, 12:43:30 PM »
how ? No one help me ?
« Reply #8 on: June 06, 2014, 05:28:29 AM »
straighten the sheet.  is that  not the simpler solution?a pry bar will move even the largest plate. recently cut a sheet of 2 1/2
plate 10'x5'. 4600 lbs. setup time less than a minute.
