Hello
Guest
it is
October 22, 2026, 04:25:30 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Maxnx CL 15 and Mach3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Maxnx CL 15 and Mach3 (Read 17541 times)
canopyfx
on:
March 17, 2007, 12:20:32 AM »
HI
Just got a Maxnc 15cl and i am trying to set it up. I have been using Mach3 to mess around until the machine came in. I used the Maxnc software and I am able to jog the machine. But when I configure Mach 3 I get nothing. Well not nothing the spindle spins up when I try to jog. I have selected the Maxnc cl in the options and I have also assigned the motors per the port assignments provided by Maxnc. I get nothing either way. I am able to assign limit switches and I can see those work but nothing on motor control even though Mach3 thinks the motors are turning. Any help would be great.
joe
HillBilly
185
Re: Maxnx CL 15 and Mach3
Reply #1 on:
March 17, 2007, 06:43:09 AM »
Well something is going on if the spindle comes on when trying to jog. The axis signals (2 per axis) should be on pins 2-9 and the spindle on pin one. Does this agree with your info. In the MaxNC CL mode the pin assignment for the axis is preset to match the MaxNC controller.
Darek
canopyfx
Reply #2 on:
March 17, 2007, 10:05:03 AM »
Yes I got the pin out from the ftp site and I confirmed it with Dawson over at maxnc. I have been messing around with this for 2 days now and I cant get any axsis to move. I cant even get a peep out of the motors. But when I switch back to the Maxnc conrtoll software it works fine. Do i have to turn a driver on or is it automatic?
HillBilly
185
Reply #3 on:
March 17, 2007, 10:10:21 AM »
You have to set these outputs up in the software also.
16.............. OUTPUT, DISABLE POWER TO MOTORS (LOW=NORMAL, HIGH=DISABLE)
17.............. OUTPUT, RESET CONTROLLER (LOW=RESET, HIGH=NORMAL)
Darek
canopyfx
Reply #4 on:
March 17, 2007, 10:15:46 AM »
16 is estop right? what is 17 suposed to be connected to?
HillBilly
185
Reply #5 on:
March 17, 2007, 10:25:01 AM »
I think I used the enable output on both of them. One active low and the other active high.
Darek
canopyfx
Reply #6 on:
March 19, 2007, 09:47:55 AM »
Any idea on the set up to regain control of the spindle? I have it set to pin 1 port 1 but what do I need to clik on the spindle set up to make the motor stop running continusly? I have the
PWM control checked
and disable spindle relays checked.
Is there anything else?
Joe
HillBilly
185
Reply #7 on:
March 19, 2007, 11:59:26 AM »
Change the active LOW/HIGH setting for #1 output. If I remember correctly, the step and direction spindle control worked with less pulsation at lower speeds than PWM.
Darek
Print
Pages:
1
Go Up
« previous
next »
