Hello Guest it is November 10, 2026, 11:09:35 PM
Author Topic: phase converter error when I stop spindle <<HELP  (Read 11032 times)
Offline Learn
  •  75 75
« on: May 17, 2014, 07:06:18 AM »
If I am doing manual work and I shut off the spindle the phase converter errors out making me go behind the machine and hit the rest button . ??? not sure if this was an issue with the old owner as he had a different converter on it . long story short the old owner switched it to a single phase so I could run it in my garage )
any and all help is greatly appreciated
Re: phase converter error when I stop spindle <<HELP
« Reply #1 on: May 17, 2014, 05:11:27 PM »
Most VFDs show an error code an the manual will tell you what the error code means. If your spindle slows down real fast it may be regenerating and cause an over voltage condition if it doesn't have a braking resistor.  That can be fixed by reducing the deceleration rate.
Offline Learn
  •  75 75
« Reply #2 on: May 17, 2014, 08:32:51 PM »
Offline Learn
  •  75 75
« Reply #3 on: May 19, 2014, 03:52:07 AM »
I think I figured it out. I think it was my pulley configuration .
Offline Learn
  •  75 75
« Reply #4 on: May 22, 2014, 04:13:18 AM »
I will have to adjust after all . Fail
