Hello Guest it is October 23, 2026, 02:35:41 AM
Author Topic: Mach 4 Hobby Demo build 1767 is available  (Read 34961 times)
Offline smurph
  •  1,575 1,575
« on: May 13, 2014, 01:42:28 AM »
Build 1767:
http://www.machsupport.com/wp-content/uploads/2014/04/Mach4Hobby%20Installer-1767.exe
The plugin file extensions have been changed from "dll" to "mp4w".
The keyboard plugin has been reworked to only affect the Mach GUI.  If Mach loses focus, the keyboard driven action/input will stop.
Steve
« Last Edit: May 14, 2014, 12:58:00 PM by Overloaded »
Re: Mach 4 Hobby Demo build 1767 is available
« Reply #1 on: May 13, 2014, 04:35:47 AM »
STEVE
This link goes to 1762 not 1767
Graham
« Reply #3 on: May 13, 2014, 06:47:56 AM »
Something appears to be damaged in jogging.
Will not jog from screen buttons.
Will not Ref All Home.
« Last Edit: May 13, 2014, 06:50:37 AM by Overloaded »
« Reply #4 on: May 13, 2014, 06:55:26 AM »
All File ops and some Run Ops are disabled ... grayed out.
You sure this is the right 1767 release ?
Russ
« Reply #5 on: May 13, 2014, 07:01:00 AM »
no,  :-X
« Reply #6 on: May 13, 2014, 07:11:35 AM »
ok, much weirdness, going back to 62 for now.
Dro's don't show movement, only updates the position when Left goes UP.
Russ
« Last Edit: May 13, 2014, 07:13:27 AM by Overloaded »
Offline smurph
  •  1,575 1,575
« Reply #7 on: May 13, 2014, 05:19:21 PM »
There is a new 1767 out there now.  It should be better.  There were some "issues" in the original.
Also, the greyed out screen buttons were testing the "Enabled States" property.  There is still a slight issue with that which I'm working on now.  Just clear the Enabled States property on the controls that are not working correctly and that should clear them up.
Steve
« Last Edit: May 13, 2014, 05:21:36 PM by smurph »
« Reply #8 on: May 13, 2014, 05:43:30 PM »
Steve
Out there ? Out where ?  ::)
Russ
Offline smurph
  •  1,575 1,575
« Reply #9 on: May 14, 2014, 12:45:30 PM »
On the MachSupport website.  I gave the link above but botched the build number.  I can't edit that post for some reason...  So here it is again.  This is the same link that you will get to if you download Mach 4 from the website by hitting the download button.
Steve
