Hello Guest it is November 07, 2026, 01:37:11 AM
Author Topic: M4 and Mill Wizard  (Read 16717 times)
M4 and Mill Wizard
« on: May 11, 2014, 09:46:16 PM »
HI RON, I noticed the old version had a link to Mach4 and the latest version does not . I still see that the mach4  HOTKEY will open the older version still.
Are you going to be able to use Mill Wizard from inside MACH4 ???
If not there is a solution I have tested and works.
Just a thought, (;-) TP
Re: M4 and Mill Wizard
« Reply #1 on: May 12, 2014, 06:40:17 AM »
yes, that is the plan. Brain did some work on that a while ago, so when Mach4  is released it should be there.
