Hello Guest it is October 23, 2026, 12:53:10 AM
Author Topic: ? about MachPlc.mcs file in Mach4Mill folder ?  (Read 13072 times)
« on: May 09, 2014, 07:40:00 AM »
What is this for and is it used or seen by the sw ?
Looks like a template ? Write your script here to test, debug then save somewhere else ?
Reason I ask, I had some script in there and saved then closed. Then M4 would not start up, just blank screen "not responding".
Just curious.
Russ
Re: ? about MachPlc.mcs file in Mach4Mill folder ?
« Reply #1 on: May 10, 2014, 05:27:20 PM »
That PLC script is for the wxMach.exe Static GUI. So if you stay in MachGUI.exe it will not that PLC code.
Brian
www.newfangledsolutions.com
www.machsupport.com
