Mach Discussion => Mach4 General Discussion => Topic started by: Overloaded on May 09, 2014, 08:40:00 AM
What is this for and is it used or seen by the sw ?
Looks like a template ? Write your script here to test, debug then save somewhere else ?
Reason I ask, I had some script in there and saved then closed. Then M4 would not start up, just blank screen "not responding".
Just curious.
Russ
That PLC script is for the wxMach.exe Static GUI. So if you stay in MachGUI.exe it will not that PLC code.
Brian
