Hello Guest it is October 21, 2026, 01:58:14 PM
Author Topic: True 45 Degree angles on XY axis  (Read 20083 times)
Mike S.
« on: February 24, 2006, 09:52:12 AM »
I am a new user of Mach 3 and am having trouble getting a true 45 degree movement on my XY axis. Am I missing
something..... Please help......
Re: True 45 Degree angles on XY axis
« Reply #1 on: February 24, 2006, 10:58:19 AM »
What do you mean? Are you having the controller move a certain distance and then manually measuring the actual movement? What is the commanded movement? What were the actual measurements?
« Last Edit: February 24, 2006, 12:21:18 PM by kdoney »
Mike S.
« Reply #2 on: February 24, 2006, 11:26:59 AM »
Thank you for your response..... When we tell the XY axis to travel a certain distance at a 45 degree angle the angle is actualy coming out at 43.8. Is there an adjustment in the Config file or somewhere that we can correct this.... or to check. Thank you in advance.......
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #3 on: February 24, 2006, 12:04:17 PM »
do you have back lash in the x and/or  y axis
is the cutter running off before the end of the angle
Graham.
« Reply #4 on: February 24, 2006, 12:20:14 PM »
If you make straight cuts in X or Y, are they then correct?
Offline Keith
  •  187 187
« Reply #5 on: February 24, 2006, 03:16:12 PM »
Is your machine 'trued up' properly?
