Hello Guest it is November 21, 2026, 02:19:48 PM
Author Topic: New posibilities  (Read 20367 times)
New posibilities
« on: May 08, 2014, 06:21:50 PM »
Here is a sample of a Mach4 Manuals page where you can read the manuals AND a page were you can access THE NFS Mill Wizard and be running mach4 cutting a part and creating the next part at the same time.
 It is a little shaky on running the Wizard, IF you MOVE the window Mach4 will stop untill you release the window grab.
But it DOES seem to work.
I created a Wizard part then load into Mach4 and ran while I created another part and saved ready to run. AND did a third part.
Interesting, AND I am sure there is a better way to do this BUT it worked.
« Last Edit: May 08, 2014, 06:27:05 PM by BR549 »
