Hello Guest it is November 13, 2026, 09:48:21 AM
Author Topic: Screen Colour????  (Read 10940 times)
Screen Colour????
« on: May 06, 2014, 01:20:01 AM »
Hi there, a big THANK YOU to all who helped me with my limit switch problems, all advice was used and the end result is great..... so THANK you ALL  :D :D,, just a quick question: at my age the eye sight is starting to play up a bit, the blue project on the black back ground is very difficult to see some times is it possible to change one or the other?  when running a program that is.
Regards
Nick
Re: Screen Colour????
« Reply #1 on: May 06, 2014, 03:27:51 AM »
You can change the toolpath colours by going to Config menu then Toolpath.
Take a screenshot or a note of the values that are default just in case you need to revert to them at any time.
« Reply #2 on: May 06, 2014, 04:42:12 AM »
Thanks Hood, I am trying the white background, it looks very promising.
Nick
« Reply #3 on: May 06, 2014, 06:09:08 AM »
There are issues with using lighter colored backgrounds that you might run into.
Your best bet may be to keep the black background and change the blue to a brighter color.
« Reply #4 on: May 06, 2014, 06:33:16 AM »
Thanks Gerry, I will try it with another brighter colour instead of the blue.
Nick
