Mach Discussion => General Mach Discussion => Topic started by: Naijin on May 06, 2014, 02:20:01 AM
Hi there, a big THANK YOU to all who helped me with my limit switch problems, all advice was used and the end result is great..... so THANK you ALL :D :D,, just a quick question: at my age the eye sight is starting to play up a bit, the blue project on the black back ground is very difficult to see some times is it possible to change one or the other? when running a program that is.
Regards
Nick
You can change the toolpath colours by going to Config menu then Toolpath.
Take a screenshot or a note of the values that are default just in case you need to revert to them at any time.
Thanks Hood, I am trying the white background, it looks very promising.
Nick
There are issues with using lighter colored backgrounds that you might run into.
Your best bet may be to keep the black background and change the blue to a brighter color.
Thanks Gerry, I will try it with another brighter colour instead of the blue.
Nick
