Hello Guest it is November 22, 2026, 01:16:03 PM
Author Topic: Lua Editor Crashing  (Read 56985 times)
Lua Editor Crashing
« on: May 05, 2014, 06:38:50 AM »
Been studying Lua using online tutorials and script examples including some of those in M4.
EVERY time I debug/step through the scripts in the editor, upon completion, there's a pop up that says "..... encountered a problem and needs to close" and the editor shuts down. Every time. Any script. All compile w/no errors. Just crashes after last line.
Something I need to do to correct ?
Russ
Re: Lua Editor Crashing
« Reply #1 on: May 05, 2014, 10:59:27 AM »
That happened a LOT in the early versions have not seen it lately.  Lua is very sensistive to a rock head like me telling it to do things that it does not understand(;-). Made good sense to me BUT LUA did not have a sense of HUMOR ?
Offline smurph
  •  1,575 1,575
« Reply #2 on: May 05, 2014, 11:44:22 AM »
Russ, are you running XP or any other 32 bit OS?  Just curious...
« Reply #3 on: May 05, 2014, 11:51:04 AM »
Thanks TP,
  Brian's Bolt Hole Wizard cycles through OK ... the 3 M4 macro's, as well as anything I compose crashes.
Must be me, just tryin' to get a better  (beginning) understanding.
Much to learn, back later.
Russ
« Reply #4 on: May 05, 2014, 11:54:20 AM »
Yes Steve, sorry I didn't mention that.
XP Pro 2002
SP3
Russ
