Hello Guest it is November 10, 2026, 02:37:10 AM
Author Topic: Multiple G-Codes on Mach3  (Read 13118 times)
« on: May 01, 2014, 06:07:56 AM »
Can I load and run multiple G-Code files into Mach3? I need to profile a hole then pocket finish it to 19mm but can't see any way to program that in V Carve. I tried 2 different toolpaths, setting the pocket cut with a 5.5mm cutter and then the profile to a 5mm cutter (which is it's size) but post processor I use (Mach2/3 Arcs (mm)) doesn't let me use multiple 'tools'. So I can generate as single G-Code files but I can't see any way to load multiple files?
Some call me Jonny.
Re: Multiple G-Codes on Mach3
« Reply #1 on: May 01, 2014, 06:28:20 AM »
I've just found the wonder of pocket allowance! However, the question still stands about multiple codes!
Some call me Jonny.
Offline ZASto
  •  434 434
« Reply #2 on: May 01, 2014, 06:42:03 AM »
When saving toolpaths, select all of the generated ones and check "Output all visible toolpaths to one file" checkbox.
My personality is who I am.
Offline ZASto
  •  434 434
« Reply #4 on: May 01, 2014, 06:50:31 AM »
Use one of the Mach3 ATC posts, and you can output multiple toolpaths with different tools.
« Reply #5 on: May 01, 2014, 09:44:11 AM »
NO only 1 Gcode program per load. NOW you can stack up serveral files in 1 program BUT you have to delete out any mid file M30,m20,etc as those will stop the file at that point.
