Hello Guest it is November 13, 2026, 07:42:58 PM
Author Topic: Trying to use Mach 3 with EngraveLab 5  (Read 10875 times)
« on: March 15, 2007, 09:25:06 AM »
I am new to Mach 3 and am trying to use it with EngraveLab 5 as the DXF file creation software. So far not much luck. I seem to not be finding the CORRECT filter, since my .25" depth goes to 3/4 inch. Up Z for travel becomes DOWN Z.. and it moves in 100ths of an inch on real time travel which takes 20 minutes to make a 3 inch letter " T "
I suspect I am doing something wrong ....
Richard
Re: Trying to use Mach 3 with EngraveLab 5
« Reply #1 on: March 18, 2007, 08:58:17 AM »
Are you using Lcam to convert the DXF to Gcode? If so I think you need to see the Lcam video on the Videos page.
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: March 18, 2007, 02:42:37 PM »
Actually , I have made progress. I am now using SignLab 7 with the Engravelab module. I find it working better, but still dosen't pass along proper depth, and speed settings.
