Hello Guest it is October 21, 2026, 04:42:06 AM
Author Topic: shuttlepro plugin  (Read 21187 times)
archimaide
shuttlepro plugin
« on: March 15, 2007, 02:15:57 AM »
Hello everybody,
I'm new new on this forum because I never had any problem with the Mach software.
But I have a shuttlepro since some years for video editing, but it comes from "Hercules" ( www.hercules.com ).
When i try to make it work in Mach3, nothing happens. I don't know what to do to make it work.
The vendor ID for my device is :
USB\VID_0B33&PID_0011&REV_0100
Can somebody help me to make it work?
Besr regards
Re: shuttlepro plugin
« Reply #1 on: March 15, 2007, 07:43:50 AM »
I don't know if the old ones are going to work :( The hardware ID is not the same and I don't even know if the data is in the same order... Best thing you can do is get a new one for mach3.
Sorry about that
Brian
www.newfangledsolutions.com
www.machsupport.com
archimaide
« Reply #2 on: March 15, 2007, 08:42:20 AM »
OK
thanks for that quick answer.
I will buy a new one immediately
2001lightning
« Reply #3 on: March 24, 2007, 01:52:54 AM »
Is the shuttlepro version 2 the only model that works with the plugin written for mach3??   Or does the silver shuttlepro work with it?
« Reply #4 on: March 24, 2007, 10:34:38 PM »
Yes it is the only one that works well
www.machsupport.com
Offline Greolt
  •  956 956
« Reply #5 on: March 25, 2007, 03:43:42 AM »
Regarding Cont/ Inc mode for the center ring.
It defaults to Continuous mode. Can I make it default to Incremental?
Reasons are twofold.
I use the outer ring for continuous type movement and use the inner ring for sneaking up on edges etc.
I would prefer to not devote a button to select Incremental.
In other words I only want it to work as Incremental and not Continuous.
Greg
« Reply #6 on: March 25, 2007, 08:00:20 AM »
There is not a setting for that :( but you could set Mach 3 to be in inc mode by default (just change it on the tab screen) and I think that will do it. Or are you talking about the center dial? If so we would have to change that in the plugin.
thanks
Brian
www.machsupport.com
Offline Greolt
  •  956 956
« Reply #7 on: March 26, 2007, 12:36:34 AM »
OK Brian can I make a request that the option to have Incremental as the default be included.  ;D
Greg
« Reply #8 on: March 26, 2007, 12:38:37 PM »
I knew you were going to do that! ;) I don't have a shuttle at this time so I have no way of testing it :( I will see if I can order a new one at some point.
Brian
www.machsupport.com
« Reply #9 on: March 29, 2007, 10:44:15 PM »
Hi, Brian,
I also would like to add my vote to the request that the inner knob be selectively made incremental. It just makes sense: you jog coarse with the outer ring, and then you sneak up on the touch-off with the inner ring. That would be a great addition to the Plugin!
Thanks!
-Pat-
There are no shortcuts to anyplace worth going.
