Mach Discussion => General Mach Discussion => Topic started by: archimaide on March 15, 2007, 03:15:57 AM
Hello everybody,
I'm new new on this forum because I never had any problem with the Mach software.
But I have a shuttlepro since some years for video editing, but it comes from "Hercules" ( www.hercules.com ).
When i try to make it work in Mach3, nothing happens. I don't know what to do to make it work.
The vendor ID for my device is :
USB\VID_0B33&PID_0011&REV_0100
Can somebody help me to make it work?
Besr regards
I don't know if the old ones are going to work :( The hardware ID is not the same and I don't even know if the data is in the same order... Best thing you can do is get a new one for mach3.
Sorry about that
Brian
OK
thanks for that quick answer.
I will buy a new one immediately
Is the shuttlepro version 2 the only model that works with the plugin written for mach3?? Or does the silver shuttlepro work with it?
Yes it is the only one that works well
Regarding Cont/ Inc mode for the center ring.
It defaults to Continuous mode. Can I make it default to Incremental?
Reasons are twofold.
I use the outer ring for continuous type movement and use the inner ring for sneaking up on edges etc.
I would prefer to not devote a button to select Incremental.
In other words I only want it to work as Incremental and not Continuous.
Greg
There is not a setting for that :( but you could set Mach 3 to be in inc mode by default (just change it on the tab screen) and I think that will do it. Or are you talking about the center dial? If so we would have to change that in the plugin.
thanks
Brian
OK Brian can I make a request that the option to have Incremental as the default be included. ;D
Greg
I knew you were going to do that! ;) I don't have a shuttle at this time so I have no way of testing it :( I will see if I can order a new one at some point.
Brian
Hi, Brian,
I also would like to add my vote to the request that the inner knob be selectively made incremental. It just makes sense: you jog coarse with the outer ring, and then you sneak up on the touch-off with the inner ring. That would be a great addition to the Plugin!
Thanks!
-Pat-
It is in the plugin at this point. you need to set one of the buttons to swap the mode.
