Hello Guest it is November 24, 2026, 06:14:35 PM
Author Topic: BRAINS  (Read 9364 times)
BRAINS
« on: April 24, 2014, 02:55:50 AM »
Hi there, I have just purchased Gerry's screen 2010, and when doing the installation it tells you to go to the "OPERATOR.... BRAIN CONTROL... enable brains.. BUT allas and behold there are  NO   BRAINS in the BOX to enable, can some one please help me to put some Brains into the Brain Box..    :P ???
Thanks in advance
Nick
Re: BRAINS
« Reply #1 on: April 24, 2014, 07:22:02 AM »
Sounds like you installed the screenset in the wrong place.
The brains should be in your \Mach3\Brains\folder
If you look in your mach3 installation folder, do you have a \Mach3\macros\2010\ folder? I'm guessing that you don't.
You're better off emailing me directly for help, as I may not always see messages posted here.
Re: BRAINS
« Reply #2 on: April 24, 2014, 10:17:42 PM »
Thanks Ger21, I have re-installed it and also up graded Mach3 to the latest version and all is working well so Far!!!. Now to set up the table co-ordinates ans soft limits, should be fun
Regards
Nick
