Hello
Guest
it is
November 22, 2026, 08:25:19 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Getting text to a macro
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Getting text to a macro (Read 10606 times)
Calum
45
on:
April 20, 2014, 12:18:17 AM »
How can I pass a text string from Gcode to a macro? I would like to write the tool description from my CAD to the tool table.in Mach3 to help ensure I load the correct tool when I manually change tools. I can get the tool number and diameter into the macro but haven't found a way to gwt the description.
Calum
BR549
6,965
Re: Getting text to a macro
Reply #1 on:
April 20, 2014, 04:02:21 PM »
Hopefully you ment CAM. Just mod the post to include the description of the tool in brackets . AND the M00 to stop the program so that you can see it in the Mach3 message line
( tool description)
M00
Calum
45
Reply #2 on:
April 20, 2014, 04:25:03 PM »
Thanks BR549,
Yeah I did mean CAM.
I have Mach3 configured to stop of a tool change so I could put the tool description after the TxM6 on the same block to see if that would work. I have it in the block before the TxM6 but the info is gone when I come to replace the tool. I sometimes need to scroll back the part code to verify the next tool which is a bit of a pain.
I was hopping to write out the tool list required for the part at the beginning of each run, just trying to be clever.
Calum
HimyKabibble
1,687
Reply #3 on:
April 20, 2014, 05:03:26 PM »
Modify your POST to output a comment, in parens, that contains "MSG " followed by your tool description. Make sure it comes out just BEFORE the M6, and Mach3 will display it on the message line.
Calum
45
Reply #4 on:
April 20, 2014, 05:56:03 PM »
OK thanks I can do that. Is there a way I can access the Message from VB in a macro? Dose the Message box have a DRO number?
Calum
Print
Pages:
1
Go Up
« previous
next »
