Hello Guest it is November 13, 2026, 02:19:49 PM
Author Topic: Answer about encoder and 4-th coord  (Read 14387 times)
BlrUsr
« on: March 14, 2007, 08:59:48 AM »
Please tell me why in "config->port and pins -> Encoder/MPG's"  exist ENCODER4 , but in settings I can't see Encoder Position 4-th coord?
BlrUsr
Re: Answer about encoder and 4-th coord
« Reply #1 on: March 14, 2007, 09:11:20 AM »
I know that xencoder - that oemcode 29 , z-31, but A-?
« Reply #2 on: March 14, 2007, 07:44:25 PM »
Are you looking for the OEMcode for the 4th axis?
www.newfangledsolutions.com
www.machsupport.com
BlrUsr
« Reply #3 on: March 15, 2007, 02:41:12 AM »
Yes if this exist
« Reply #4 on: March 15, 2007, 07:33:20 AM »
Use Number 100 - 103 for ABC axis
www.machsupport.com
BlrUsr
« Reply #5 on: March 16, 2007, 04:18:04 AM »
Thanks a lot
I add oem 100 - all ok, but while I rotate encoder - it's increment or decement without limitation at 360
I use à rotate A-axis, which I want to drive manual and monitor it on mach.
BlrUsr
« Reply #6 on: March 16, 2007, 04:39:12 AM »
I use 1024-pulse encoder and 1.degree = 1024/360  = 2.844444...  pulses   and 1pulse=0.3515625 degree (doesn't metter)
I have Index signal on encoder, maybe I can use it? Such as "home" for A-axis
« Reply #7 on: March 16, 2007, 07:09:15 AM »
There is no homing to an encoder index at this time :( also we have never put in code to reset the count every 360... It is something that could be added but I think that will have to wait for quantum as we are trying to lock down Mach3 at this time.
Brian
www.machsupport.com
