Hello Guest it is October 20, 2026, 02:50:54 PM
Author Topic: Machine wont zero after Homing  (Read 72257 times)
Re: Machine wont zero after Homing
« Reply #40 on: April 23, 2014, 09:37:39 AM »
there are 2 points just under the pot on the board
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #41 on: April 23, 2014, 10:30:39 AM »
Power supply is 24V / 20A.
Gantry is waiting A Axis driver. Only have 3 at the moment. 4th in transit.
Will Check the voltage using the forumla you supplied and see if its somewhere near. Where do i put my meter to measure the Vref ?
Hmmmmm. Your power supply is not ideal - problem is you're already running your motors at little more than half their potential. Not enough V, but more Amps than you could shake a stick at.
It's not MY formula - don't be blaming me when it all lights up ;D - it's right there on YOUR board. If not then the piccy you linked to is different. Check the manual.
Hmmmmmm. are you sure they're the points you need to be measuring? Again from the piccy - there's two terminals on top of the board marked VRef and Gnd. You may be right - they may be the same thing - You guys have the boards and manual. Just checking.
« Reply #42 on: April 24, 2014, 03:18:21 PM »
Ok - If all else fails RTFM!
Your both absolutely right. The formula you gave is on the manual. (1 piece of paper.)
I have now accurately set the Ampage fairly accurately to 3Amps on all pots. (Which seems to equal 1.36 V) across the two terminals.
e.g. (1.36 * 0.333) / 0.151 = 2.999A
As I think i mentioned my programs have been crashing 1/2 way through. I initially thought this was interference, but tonight i have successfully run
programs in mid air with the cutter running, and then cutting mdf on a very slow feedrate.
I suspect the crashes occur when the motors are under more load. E.g. When the feedrate or cut depth is higher.
I did have a feedrate of 1500, and now i have dropped it to 1000.
Looking at the manual, the drivers say they have TSD (Thermal shutdown), Over Current Detection (ISD) and built in Under Voltage Detection (UVLO).
I suspect that one of these is kicking in at higher feed rates. I expect Over Current Detection - the boards are not getting hot.
Do you think a higher voltage power supply would solve this ?
What would you recommend in terms of volts required - Just reread your post.
Where the hell am i going to get a 36V 12A power supply from?
Thanks for your very useful help...
Martin
« Last Edit: April 24, 2014, 03:29:47 PM by mturneruk »
« Reply #44 on: April 25, 2014, 03:39:33 PM »
OK - So I now have screened cables all-round and I am still get skips, blips and judders at random points when jogging.
Sometimes it doesen't do it immediately, but then soon starts. Sometimes its really bad. I can't find a pattern...
When i am running a program, it seems fine.
I have ordered a 36V power supply, so hopefully that will hope with the program stopping 1/2 way through
  •  9,374 9,374
« Reply #45 on: April 26, 2014, 01:11:40 AM »
My post has been deleted as it fell on deaf ears  :-[
« Last Edit: April 27, 2014, 06:58:43 AM by Tweakie.CNC »
