Hello
Guest
it is
November 22, 2026, 02:46:08 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
Gcode MDI move to machine coords
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Gcode MDI move to machine coords (Read 14704 times)
Jimster
177
on:
April 16, 2014, 10:22:02 AM »
Guys,
I have a quick G code question for you, Can you move the machine to the machine coordinates and not the working coordintes with an MDI??
I'd like to make my machine go to x0,y0,z0 what command would I need to use?
Jim
ger21
6,295
Re: Gcode MDI move to machine coords
Reply #1 on:
April 16, 2014, 11:00:18 AM »
G53 G0 X0 Y0 Z0
Make sure the Z axis isn't going to hit anything.
Jimster
177
Reply #2 on:
April 16, 2014, 11:02:59 AM »
perfect, so simple even I can understand it, thanks Gerry
Overloaded
4,923
Reply #3 on:
April 16, 2014, 11:07:17 AM »
G30
I think does the same thing.
G28
Will go to the values set in the G28 Home Location boxes in the Home/Soft Limits dialog.
Russ
Jimster
177
Reply #4 on:
April 16, 2014, 11:09:01 AM »
ahh, I think it's G28 I need then
Overloaded
4,923
Reply #5 on:
April 16, 2014, 11:14:09 AM »
With G28, you can actually program the rout the axis' take to get home too.
Making sure everything clears.
Russ
Jimster
177
Reply #6 on:
April 16, 2014, 11:25:14 AM »
Thanks do I have to move x,y, then Z, or could I do?
G53 G0 Z0 X0 Y0
Print
Pages:
1
Go Up
« previous
next »
