Hello Guest it is November 22, 2026, 02:49:27 PM
Author Topic: Gcode MDI move to machine coords  (Read 14705 times)
« on: April 16, 2014, 10:22:02 AM »
Guys,
I have a quick G code question for you, Can you move the machine to the machine coordinates and not the working coordintes with an MDI??
I'd like to make my machine go to x0,y0,z0 what command would I need to use?
Jim
Re: Gcode MDI move to machine coords
« Reply #1 on: April 16, 2014, 11:00:18 AM »
G53 G0 X0 Y0 Z0
Make sure the Z axis isn't going to hit anything.
« Reply #2 on: April 16, 2014, 11:02:59 AM »
perfect, so simple even I can understand it, thanks Gerry
« Reply #3 on: April 16, 2014, 11:07:17 AM »
G30
I think does the same thing.
G28
Will go to the values set in the G28 Home Location boxes in the Home/Soft Limits dialog.
Russ
« Reply #4 on: April 16, 2014, 11:09:01 AM »
ahh, I think it's G28 I need then
« Reply #5 on: April 16, 2014, 11:14:09 AM »
With G28, you can actually program the rout the axis' take to get home too.
Making sure everything clears.
Russ
« Reply #6 on: April 16, 2014, 11:25:14 AM »
Thanks do I have to move x,y, then Z, or could I do?
G53 G0 Z0 X0 Y0
