Hello Guest it is November 13, 2026, 09:41:46 AM
Author Topic: Mach 3 Dry test  (Read 9336 times)
Mach 3 Dry test
« on: April 12, 2014, 09:06:52 PM »
Hello, I would like to dry-test some g-code that I have with mach 3 on a computer that is not plugged with a cnc. Is it possible and if yes, how?
Thank you very much!
David
Re: Mach 3 Dry test
« Reply #1 on: April 13, 2014, 03:27:56 AM »
Just open Mach, load the code and press Start.
Toy will however have to first change the active state of the E-Stop output so Mach will come out of Reset.
To do that you go to Config menyu, Ports and Pins, Inputs and scroll down to E-Stop and change the active state. Once you have done that then you will be able to take Mach out of Reset.
Re: Mach 3 Dry test
« Reply #2 on: April 14, 2014, 07:18:17 PM »
Thanks awesome!
It was very kind to answer quickly!
I hope I will be able to help other people with time!
