Hello Guest it is November 13, 2026, 12:00:32 PM
Author Topic: Reset pop open window?  (Read 14612 times)
« on: April 10, 2014, 03:00:46 PM »
When i had a limit switch get tripped and i need to reset it i would click the reset button in the bottom right corner and a window would open.
Now when I click the rest button nothing opens up how do i get the window to open when i click the red rest button?
Re: Reset pop open window?
« Reply #1 on: April 10, 2014, 03:56:06 PM »
This is the screen I am trying to get back?
under other profiles it will open.
« Last Edit: April 10, 2014, 04:00:54 PM by jaustin »
  •  9,377 9,377
« Reply #2 on: April 11, 2014, 04:30:55 AM »
I have never actually seen that screen buy try;   Function Cfg's / Reset Device Sel...  and see if that does it.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #3 on: April 11, 2014, 05:32:32 AM »
Must be missing something I guess. Why would you want it back? it's an error message. It only pops up when you don't have your limits set right.
« Reply #4 on: April 11, 2014, 12:25:11 PM »
I like to have it back since I am still learning and setting my mill up. I have crashed into them a couple times and was able to toggle them to get the axis of the switches.
i am going to make some handwheels to turn them off the switches.
I did email mach3 support and they said"There really is no easy way to get that message back,"
So making handlwheels sounds like the best way to solve this.
scottn
« Reply #5 on: April 11, 2014, 03:18:12 PM »
The only way (that I have found) to get that dialog back is to hack the XML via a text editor and reset the WarnOnReset value to be 1.  But, like I told John when I emailed him back this morning, the correct way to handle the situation would be to use the Limit Override options on the Settings screen...
« Reply #6 on: April 13, 2014, 07:08:15 PM »
thanks scottn, I found the override in the setting screen.
